New to me 2001 KDX220
Hi Guys,
I just bought a 2001 KDX220. It was a good deal, but needed some work. So I had the top end rebuilt with a wiseco piston, had the power valve cleaned, put some new plastic, handle bars and hand guards, new chain, and new tires to come.
I had this all done at a local shop. They changed the tranny oil, but I think they forgot to put new stuff in as I noticed there is a little "eye" on the side of the case and I couldn't see any oil in there.
Luckily there is snow here, so I haven't ridden it yet.
What type of oil should I use?
Any 4 stroke motorcycle oil will work, 700ml for my 200. Should be marked by the fill how much yours holds.
Could go into the thought of, since they "forgot" to put oil in the gearcase, what else they may have "forgot" in the rebuild.. but i won't.
Sleep well.:lol:
Bit of advice: get a shop manual, some tools, and do your own work on your bike.
If you are not fust about the oil you use a 10w 30 or 10w 40 motor oil will be ok .
10w30 would work good, but most on the shelf in that grade are energy conserving, carry the starburst symbol (not clutch friendly). Some of the "high milage" flavor 10w30 are OK, just read the labels. No 10w40 are EC, so no worries there, might be thicker than what you like though. I'd also try ATF, and see if it works better.
I used to run Motul gear oil but the Belray lightweight gear oil sure does make my bike shift a lot eaier. I noticed the clutch action is smoother as well.
Hi Guys,
Absolutley Fkn AMAZING! :lol::worthy:
No wonder I never let anyone do this activity for me.
did you hold your bike straight up and down? if its over on the kick stand or whatever you have you cannot look into it and see oil.
It was on an aluminum bike stand (not a kickstand) so it was perfectly level.
They are really good guys and they do great work, but everyone makes mistakes. I'm just glad I noticed it before I rode it.
So if I have Honda 10w40 engine oil, that will work fine? How much does the bike hold?
Lean it over to the right to see just how low it is.
Fill it to the middle part of the window.
Yeah, I leaned it way over.....there's nothing! Unless it is clear as water, but I don't think so.
Hmm. That's odd. That is a good catch on your part!!
I filled it up with Honda 4 stroke oil. It said on the back of the bottle that it could also be used for 2 stroke gear/transmission oil. It was the only think I had in the garage other than Petro Canada diesel oil.
Thanks for all the help!
I've always used ATF in my 2 storkes and never had a problem....
  • Similar Content
    • By Zach121
      Alright, found three bikes all located where i live in Texas. I know they're all very different, but if you could tell me what you think each bike is worth, and which one would be the best deal. Thanks.
      Notes: Both 2 strokes have new top ends. I think the front brake lever is broken on the kawasaki.
      KX250 2002 $800-$1000?
      YZ125 2000 $1250
      KTM 400SX 2002 $1200
    • By Ryan Turner
      So I'm at a bit of a cross roads, I currently own a 06 rm250 and I love it. I also have a 02 kx250 which I'm selling with intent to buy a newer two stroke. I can't afford a newer ktm and the older ones aren't that great and kawasaki never impressed me. so I'm stuck between 06 yz250 and 05 cr250. I've heard the yz and rm after 06 are almost the same bike just the Suzuki handles better and the Yamaha has better suspension. So I'm not sure if I wanna buy carbon copy of my bike with slight differences. That's why I'm interested in a cr250 I heard the 02+ models RC valves are shit garbage but was mostly fixed in the 05-07 models. I ride at a track and at some bogs down the road from me. So from people who have owned both, what would you recommend. I know the cr is known for a hard hitting power band which I enjoy since im an aggressive rider. Should i just see which deal comes my way first.
    • By dirtbikesrule
      If you own a 2 stroke dirtbike,please reply once. Im just wondering how many people on this site have them.
    • By 02YZ426
      I thought it would be interesting to see what everyone in this forum is riding... So post them up
      Here's my 2006
      And my buddies 1996 KX250 that I just finished fixing up. Motor completely rebuilt and ready for the track.
