08 or 09 250XC-W
Any Known pro's and con's
The only real changes I can see between the two year from KTM spec's is the seat height
Is this correct?
Is this correct?
Pretty much the same. I don't even think the seat height changed.
'09 has better forks on the xcw. they are the closed cartridge style. seat height is the same ( manuals usually have several errors).
Joe
OK understand about spec errors.
However here may be big one.
KTM says
In 09 they did a complete engine up-grade on both the XCW and XC 250 two stroke. SO this is not correct? Was the up grade done 08 as well?
ALso they say the 09 XCW has open cartride forks while the XC in 09 has closed cartridge forks from the XS. IS this wrong? what ones are better?
