quick urgent help sprockets
i just ordered sprockets for my WR250f 06, but they were for a YZ250F 05 will they fit?? YZ250f 05 sprockets on my WR250f 06.
Front and Rear sprockets
thanks in advance Ollie
:lol::worthy:
if you ordered stock, they will fit, but tooth count is proubly diff.
it was a renthal kit with X ring chain, will they mount the same??
Your 06 WR comes with 13/52, while the 05 YZF is 13/48. That is a big difference in the final drive ratio. You will have a lot less snap with that ratio but higher top speed once you get going. Are you trying to get more top speed?
oh no i selected the gearing 13/52 not stock for either bikes as mine came with 14/52 and now it should snap better but does anyone know anything about these x-ring chains???
52/14 = 3.714
48/13 = 3.692
The ratio difference is very close, so you may not feel much difference in how the bike behaves (slightly less snap maybe). X-ring chains are very good chains and Renthal is a good company... :p
so u know of these chains what type of maintenance do they require??
I've been using D.I.D. x-ring chains since 2002, all I do is wash the dirt off and spray them down with WD-40 then store and repeat process after the next ride, etc...
cool would silicon spray be better becasue i have that for my diving tanks as it dosent wear the rubber seals is this true?
I have never used that stuff on my x-ring chain. WD-40 cleans the junk off, lubricates the chain (very little) and disperses the water. X-ring chains have built-in "sealed" lubricants so you don't really need to spray them with a whole lot of external lubricants IMO. This has been working for me... :p
