Flywheel weight for 2009
Anyone know if someone is making flywheel weights for 2009? I looked around some and didn't see anything. Thinking about setting my bike up for offroad and considering the weight to smooth out the hit and help with stalling.
Eddies map and setting the idle to 1800rpm will virtually eliminate any stalling issues. If the hit you are referring to is the slight bog off idle followed by a jolting sensation this is due to a rich efi map. Eddies map will eliminate that bog and smoothout thus eliminate the "hit"
you may not need a flywheel weight, with eddies remap in mine i can compare it to my 08 with 11 oz. wt. as far as stalling goes.
