470 jetting with a 39mm FCR-MX
After a lot of searching, I only came up with recommended jetting for the BB+stroked motor with a 41mm FCR.
If there's somebody out there already running this combo with a 39mm FCR, post up your jetting setting.
If I remember correctly, Eddie did a dyno run with this setup on Jonathan's bike. Maybe he can chime in.
Would this be a good base for sea level?
158 main jet
200 main air jet
emn needle
clip 3
45 pilot jet
2 turns fuel screw
that should be fine setting.
Thanks Eddie.
I checked my pilot jet circuit today and found out that, when idle speed is set properly, the bike seems to be running/idling the best with the fuel screw at 0.75 turns out.
Is it possible that it might need a smaller jet than you recommended?
42?
Again, I'm at sea level.
If you are running an alloy fuel screw, needing a smaller pilot is not uncommon. Personally, I'd run a brass one (like the Merge Racing or Kouba) or stainless steel (Keintech) and not have this issue.
what fuel screw?
also you wan tto set the idle as low as the bike will stay running when warm for the tests.
It's a stainless screw.
I did try to set the idle as low as possible.
where did this carb come from?
eBay. Possibly an ex-Yamaha carb.
most likely the needle jet (not needle) is worn.
Could that explain a slight 1/2-3/4 throttle hesitation as well?
Should I try to replace both the jet and the needle? Or replace the jet and play with the clip position?
I would think so...... If you order from sudco they have a minimum order $....So to fill it I`d get the jet as well. You can find great info on their website about the needles in the catalog download pdf....:p:lol:
Erling
The more I ride it the more it makes sense that the needle jet might be worn out.
My jetting should be pretty good. I just replaced the o-ring so squirt should be good too. Despite that, the motor still chokes sometimes when blipping the throttle from idle, hesitates a tiny bit around 1/2-3/4 throttle and has a hanging idle every now and then. A little blip of the throttle always fixes the hanging idle - almost as if the needle was getting stuck. The cables are lubed and set up right, and the throttle is returning smoothly.
Do these symptoms make sense for a worn out needle jet?
Also, I was trying to locate it in the Sudco FCR-MX diagram so I could order it but with no luck.
Is it #26 - Main Nozzle?
http://www.sudco.com/Diagrams323728/expfcrmx.gif
Any hints?
yes,#26.
Thanks Eddie. Does it sound like this might be the source of my jetting issues based on the symptoms?
most likely but either it will eliminate a possibility.
I guess I can start with replacing the needle jet and work from there. Thanks again :p
