stripped my plastic bolt!!!
i stripped my plastic bolt on my right shroud (the gas tank bolt) what do you guys reccommend i do? thanks
are the threads in the gas tank stripped or just the bolt is stripped? If it's just the bolt then get a new one at home depot, if it's the gas tank threads, then you can try a thread chaser, if that doesn't work then you can always heli-coil
Maybe it is not possible for everyone to get a hold of, but on modern Volvo engines there are a lot of M7 threads.
The one in your tank is 6 mm with a pitch of 1 mm. That M7 bolt is 7 mm with 1 mm pitch.
A local car shop should be able to make it a M7x1 thread with a tap and give you a bolt that fits.
Or just do what LuigiC said...
I think you can pop out the nut on the tank & replace.
Good call :p
I don´t think that is possible. The nut is molded in place, you can only see "the tip of the iceberg"...
Whooooo $hit Batman!
I did it a long time ago, its not stripped bad enough where the screw falls out, so i got some red loctite and threaded is very lightly untill it set, havent messed with it since, the other screws will hold the shroud on fine.. No problems with it, I check it every once in awhile and its still holding up..
A good precaution would be to put some oil or grease on all bolts, and tighten them with common sense. And check them once in a while.
But $hit happens anyway...
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
