Pictures of New Rack
Greetings - I found this rack on ebay which appears new. Maybe it's been on the forum before but Mike, the maker of the rack asked me to send him some pictures so he could use for advertising for a XR650L. Either way here are some pictures. Mike's ebay site is: manrack-com or
I don't know Mike personally.
Thanks for posting these. For $65 and free shipping, I don't think you can go wrong. It's not a bad looking rack, plus it's less than 1/2 the price of the Pro Moto Billet. I like the PMB rack but you can't use the stock toolbag with it. Bummer. I also like the fact that the Manrack works with aftermarket tail lights. :p
Nice rack:banana:
I've used one for about a month now. Well built, mounts solidly. I wish it were about 6" longer, towards the rear, but good for light duty gear hauling .
  • Similar Content
    • By XR-CJ
      I have this issue several times and cannot seem to figure it out. The four clutch spring bolts are the weakest bolts I have ever come across. I am not sure what the torque specs are, have the shop manual, have searched online and I can only guess it's around 4 ft/lbs. I have been told 8 and they seem to break every time around 7.
      What is the proper torque for these bolts?
      Should I find stronger bolts? I would still stick to the proper torque, but feel as if these things are butter.
    • By XR-CJ
      Prior to reassembling the case, I tested the shifting and it seems the center fork attached to the shaft seems to stick at the steepest section of the drum. I have cleaned and tested all forks and surfaces for smooth movement, tried it with silicone and oil. With very little help, it seems to shift ok, but without the help, it binds.
      Can I assume that once it is together the oil lines are attached and oil is added to the case, the binding will stop? I have tested every scenario short of assembling the entire motor.
      Should I be able to successfully test the shifting with the case apart?
    • By Charles Mrizek
      contact me if you're interested.
    • By Charles Mrizek
      This replaces the tube that connects the two carbs on a 1987 Honda XR600R (it may fit other years).
      Made in the USA.
      Constructed of TPU  (solvent safe plastic.)
       Its durable stiff abrasion resistant yet flexible enough you never have to worry about breaking it when you're taking apart your carbs.
      Fits the o-ring perfectly and slips into the carb nice and tight.
      Matches the rear shock coil.
      If you would like to buy one contact me via e-mail. They cost $20 Shipping is free (anywhere in the USA). $10 off for active duty or retired military.
      Make your subject: XR600r
