Valve clearences on the 09
my 09 has done around 4hrs i would guess and iv just checked the clearences and one of the inlet is 0.9mm and the other is 0.1mm has anyone elses valves gone out of tolerence that quick? im wondering if they were tight out of the factory. Im not a agresive rider and iv maybe hit the limiter once.
Does they bike start easy? You checked them on a stone cold motor right?
They can be tight from the factory and settle a bit.Good job checking them after break in!:p Make sure you did everthing right (right timing mark and cold motor) shim to spec and keep A eye on them for a bit.Chances are they'll stay put.:ride:
my 09 was fine but i had 2 others a 05 and 06 250F who was tight from factory.
Yes cold motor been in the garage for few day. I checked and double-checked all marks were as there supposed to be. Admittedly from day one it wasn’t 1st or 2nd kick from cold more like 5th or 6th but would start. I guess it must have been tight out the factory, was worried that the valves had stretched in 4hrs. I’ll re shim and have another check in another 4hrs to be safe. My luck I check two days before I’ve got a day off mid week to go for a ride. Hopefully I can get the shims in time.
  • Similar Content
    • By DirtBikeHead
      2015 Kawasaki KX250f - 20 hours
      As close to new as I'd imagine you'd get! I bought the bike brand new, I'm older and have taken extremely good care of this bike. Very little use and is COMPLETELY stock - everything is original.
      Comes with the title, original book and map couplers for the fuel injection.
      $4700 - cash
    • By CodyR
      Just thought maybe everyone could post up there youtube channels an we could all help eachother out by subscribing to one another.
      Heres mine ill sub back asap.
      This has been fun in other sections of TT, so I'll start the thread here and see if we can keep it going.
      Let us know what kind of mods, fixes, changes, etc.., you performed today, or just general fun you had with, your KX250F.
      I'll start with.. I installed a correct for my weight Race Tech shock spring, along with a Pivot Works shock spring thrust bearing. Also cleaned out all the nasty yellow plastic/wax crap that passes for grease in the lower shock bearing, and re-lubed it with Bel Ray waterproof.
    • By bangmyhead
      Time for a top end on my bike, just wondering if there are any alternative Valve springs i can use. I have PC cams and $400 for just the springs and retainers is alil costly at the moment.
    • By MotocrossMaverick
      Hey guys i have just gotten off my Honda crf150r and i am looking for a new bike. I have been to the dealership and have already checked out the Kx250f and the Crf250r. I am looking more at the Rm-z250 then any other bike right now. I need help finding what bike would be best for me. I have never been on a 250 but i am starting racing about a month after getting the bike. I was also offered $5800 for the Kx250f and i know it killed 2012 i am just not sure about a Kawasaki. Honestly i am not sure bout any please help!!
