Need help on jetting Mikuni TM28 flat slide
Bought a new pitpro lxr 160-r , did the cylinder, head & carb trick to it.
Engine - YX160 w/184cc cylinder/short skirt hi comp. piston kit and V2 roller rocker head kit
Carb - Mikuni TM28 flat slide w/ rear facing intake and uni filter
Pipe - 32mm big bore (stock), no spark arrestor or silencer installed
Elevation - 1,305 ft above sea level
Riding weather temp. - 80 to 95 degrees Farenheit
Fuel - 91 octane premium unleaded, toulene can be added to the gas to boost the octane higher if needed
Riding Style - Mainly trails, some flat-track, some motarding.
Was wanting to know what:
main jet size -
pilot jet size -
fuel screw setting -
recommended octane -
thanks for any input, greatly appreciated.
