is this DRZ a fair price?
2005 DRZ 400 S, completely stock, 1,100 miles.
Selling for $3,700.
I think the price is a bit high since 2008 models were just cleared out around here for $4,999.
What do you think?
You got it for trade in price on kelly blue book.
I'm just posting about an ad for a DRZ locally for sale. I don't know the person who is selling it.
I went to and it said the average retail is $3,015.
Either way I think the price is high.
What do you guys think?
Very low mileage. $3200 would be a fair offer
I just paid $5999 for my 2009. I tried getting some dealerships around here to budge on the msrp price of $6699 but nobody would because they're moving the bikes out so fast. I went in yesturday which was the last day of February and got them to drop $700 off the price so I took it.
with 2200 miles I will sell for $3800. I will be selling my farkled 2007 also as my goal is to get a 2008 FI TE 610.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
