Crush washer question...
Sorry if this is a dumb question but I can't come up with an answer in search mode. Does the narrow side go to the bolt head and the wide end to the case? The parts guy said the opposite and I am not convinced that is right, my old one was flattened beyond recognition.
Yes, my Suzuki DR-Z400S/SM Service Manual shows wide side toward crankcase and pointed side toward bolt flange.
What's the part number for the Honda crush washer that can be used?
12mm Honda part # is 94109-12000.
I'm sure this has been covered also but is it OK to use a copper flat washer (old school way) on the frame drain plug?
copper is fine.
Yes it has.
Tipsy
Thank you very much.
:p
I was about to order 10 of these from the TT Store, only $ .43 each... however the $9.99 shipping has me thinking about stopping into the local honda dealer instead :p
