Where could I finde fork springs in Germany?
I need to replace stock springs with more suited for my weight...
Where could I finde shope like "Race Tech" in Germany or Austria?
I need this springs:
1999 Honda XR400R
Type of Riding: Desert / Enduro / Trail
Rider Weight: 85 kg
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.462 kg/mm (use closest available)
Stock Fork Spring Rate: .382 kg/mm (stock)
www.racetech.com
Thanks forward...:p
i will have a new set of springs (1 yr ) out of my bike...i know they are race tech and r set for a 200lb rider...if you can find a way you can have them...and funny thing is i will be in germany next week on vacation...no i cant bring them sorry
I don`t have any possibility to bring them from USA...
Anyway,thanks...:p
I send email to Wilbers company(Germany) and this is theirs answer:
Dear Ivan,
thank you very much for your inquiry and the interest in our products!
Unfortunately we don´t have fork springs for Honda XR 400 R in our program. But if you can inform us about measurements we are able to see if we have fitting fork springs from another model in stock, we need:
- length
- outside diameter
- numbers of windings
- numbers of narrow windings (if they are progressive)
- distance between the windings
- Negative sag (static and dynamic)
- Preload
Thanks for your trouble.
Best regards
Vanessa Naber
Wilbers Products GmbH
Frieslandstr. 10
48527 Nordhorn
Tel. +49 (0)5921 727170
Fax +49 (0)5921 74099
info@wilbers.de
www.wilbers.de
Private limited company
Company's registered office: Nordhorn
Commercial registry: district court Osnabrück, HBR 130484
Executive director: Bernardus Wilbers
----- Original Message -----
To: info@wilbers.de
Sent: Monday, March 02, 2009 11:17 PM
Subject: Fork springs for Honda Xr400r
Hi...
1999 Honda XR400R
Rider Weight: 85 kg
FRONT FORK SPRINGS
So...0.46 kg/mm will be just fine.
Are you have this springs and wat is the price?
Thanks forward...
Ignjatovic Ivan
Anybady knows this:
- length
- outside diameter
- Preload
