YZ Experts PLZ Help
I need help from those who are extremely fimiliar with the difference between a 93 to 98 bottom end compared to the current bottom ends. Specifically the stud pattern to bolt the cylinder to the cases. IE: I would like to use a 65 cylinder on a 07.
Thanks Jay:ride:
The pre 98 cylinder does not fit on the newer bikes. The stud pattern is different as is the bore and stroke.
I am sure someone could MAKE it fit, but it would not be easy.
How about bolting a older motor in a aluminum frame???
Sorry guys I didn't see the first post......
That should be do able
A straight bolt in????
