acct convert to mcct
How to do it? Convert acct to mcct
can i make one?
Unless you are a machinist I wouldn't try it. If the cam chain tensioner fails it WILL cause major engine damage.
If there is any glue involved it would be the Copernicus CCT
is there anything wrong with the acct ? my bike has a little over 11k and it runs just fine
Problem with acct is that they could fail ,and causing total disaster in the engine.
The pin is spring-loaded ,and it tends to bee too tight , stretching the cam chain.
When letting off the throttle/deacceleration it could jump out ,causing chain to skip some teeth on the cams..
Mcct is a very cheap way to awoid disaster.
It's a quite cheap mod , is no point making your own :p
lol,havent seen old copernicus around since then.
ahh well now that someone explained what it does i might look into one
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
