07 450 EXC Clutch Question
When the bike is on the stand, I pull in the clutch and drop it into gear. The clutch is still pulled in and the rear tire is moving. Is this norm? When its on the ground it dont move. Also when i push the bike around in gear with motor off and in gear its hard to push.
the clutch has more drag when the motor oil is cold as it is a wet clutch, when it's good and warm it is much easier to push in gear. cold oil is thick oil.
its normal, also this question is asked every week or two so you could look up the other posts to see any other answers too.
