plz help, bottom end
so im trying to take off the crankcase to replace the crankshaft, but in clymers it says to remove the flywheel and the clutch. I was wondering if these two steps are necessary, so are they? and if so is there any way to take off the flywheel without the flywheel remover tool thing? (not sure what it is called)
yes, yes , No.
Follow the book.:p
Sorry I'm in Thailand.
You will need the flywheel puller, the clutch basket holding tool and the case splitter.
To put it back together you will need the crank puller.
is it easier to take the flywheel and clutch off when it is connected to the frame or should i take the bottom end off then take the flywheel and cluch off?
