xr 200 forks
The seal on the air valve is bad and therefore leaks. You should easily replace the air valve seat...
The shrader valves may be bad or lose like the ones in a tire or tire tube .Replace or see it tightening them helps.If it happening when you lettting air out of them it happens sort of like a water ballon with air the air pressure will force some warter or mist out .
