Will i regret changing my dr for rmz
Hi i am trail rider not a racer i have dr 350 s it,s been trouble free for the past 4year .i have serviced after every 3 outing anyway i want somthing a bit newer so are at a rmz 250 2005 are these low maintance bike or like the crf need rebuilds on the top end if any one can help many thanks garf:
Personally i think if your changing your bike for a slightly newer second hand bike, you should keep your old one... You know the history.
The RMZ has to be looked after the same as any 4stroke. If something goes bang it can cost a lot of money!!! Valve clearances are a must and also correct oil and filter changes. Its not rocket science but must be done.If you decide to get the bike it may be worth changing the piston just as a pre-caution as they can crack with abuse... You will pick a kit up for no more than £100
If you know the history of the RMZ i would buy it as i recon you will have more fun, but im biast!!!!!:p
