Unabiker 20 min. easy install
Before you start make sure you have the right tools. You will need 2 4mm hex keys,10" extention w/10mm socket. The most important thing DO NOT tighten the the button head screws in supportrods. Line up the radiator with frame mounting holes on the radiator guard. Then tighten the buttonheads, Then mount theradiatorsIMG_0072.jpg tIMG_0066.jpgo frame and tighten every thing up.Done
Nice job! Great guards!
Mike :p:ride:
They come in 4 (four) designer colors.
i mounted the S model versions on my S back in 2004 & had no problems.
no issues removing & re-installing fuel tank after mounting. love these guards.
this weekend i attempted to mount the E model versions on my '01 E.
it took all i had to not throw them thru the wall.
como se dice....not even close.
got the left side mounted up. after filing, drilling & grinding the next day i had to pull the tank for another reason.
it made putting the tank back on such a PITA, i took it off.
since i run a horn on my E(not unabikers fault) the right side would require re-locating the horn.
looks like i would have had a better shot @ mounting the S model versions on my E.
I bet it took me four hours to get them on my WR. What a monster PITA.
I just had to keep telling myself, its worth it.
Thank you for your reply and input aspencop129.
They won't go on in 20 minutes with a Yosh header. Not that difficult,but rather time consuming. Many test fitments to get enough clearance without grinding on the support strut.
