xr650L side pin mod
I have lost a couple of the 1/4 turn pins and washers that hold on the left side cover. First I just put some duck tape over the pin recess, which works but didn't look very good. Now I have used bicycle derailure cable to form a loop around the handle and crimped it with an electrical connector, I drilled 1/16 hole in the side panel and ran the loop end through the hole and soldered another crimp end on the tail to keep it pulling though. I attached the washers to the side panel with a small amount of JB weld. Now all the mounting hardware is attached to the panel itself, no more lost pins or washers.
Cool, got a pic?
Hi,
Aren't there the teflon washers on the inner side to keep these from falling off? Or did you lose those too? I do alot of rough off road trails and have spilled the bike a few times and never lost these. Maybe the airbox side is worn? Well it sounds like you've got it whupped, was just curious.
I see, Your setup now pretty much garauntees you'll never lose them again. Nice idea and good pics.
A plastic milk jug or soda bottle trimmed will function great for the washers. I have used them for thousands of miles.
