2006 YZ250F crank
I took the left side fly wheel cover off of my bike to check out if the crank had any play in it. It doesnt have any up and down play but I can push it in and out about 1mm or less, can anyone tell me if that is normal?
I believe its the up and down movement that is a problem, which means your crank bearings need replacing.
so you think its normal for a small amount of play in and out as long as theres no up and down movement?
