Headlight Aimed Too High, Check The Wiring
I am in the process of adding a high/low/off switch in for the headlight. Cutting Torch mentioned on another thread the stock headlight is wired to the high beam(Red Black wire). This was true on my bike, but the owners manual shows the stock power wire going to the low beam! My wire layout is also different than the manual. I almost reversed the High/Low beams. You can change the beam pattern by simply pulling the male terminal on the bike side(Red/Yellow wire), and matching it to the low beam(Red/Yellow wire) on the headlight. I used a small pick to remove the terminal. The change in beam direction is noticable.
