How I wired my drz400e to dualsport with Acerbis Cyclops
So here is how I hacked together my turn signals, cyclops, brake light. You will notice that I set it up with the Projector running off the stock headlight wire(always on with Key on) and the running light in the wide lens as the low beam. What this allows is the wide and the projector to both be on when High Beams are on with out the use of the usual mod that causes dimming...
Anyway it ain't pretty but it works.
Here is the wiring diagram
Here is the stock diagram for reference for reference:
