6volt mini blinkers
I bought some 12v ones from RMATV, then bought some 6volt flashlight bulbs from Ace. The bulbs don't have the nubs to keep them in the socket but I crimped the socket just a little bit and they stayed in fine. I only have a days use out of them but they worked good so far and are pretty bright.
http://www.rockymountainatv.com/productDetail.do?navType=type&navTitle=Electrical&webTypeId=300&webCatId=20&prodFamilyId=19546
Most bulb styles come is several voltages. You do need to know what base the bulb is before you can get the correct substitution. A place like www.donsbulbs.com can help you determine what the base is and what might be available. Don is real expensive though.
