CR230F Baffle
I need a Exhaust baffle (not the spark arrestor ) . Anybody got a spare one sitting around after changing pipes they'd like to part with cheap.
I did some experimenting with mine (cut it up )and now it whistles ,and I dont like it ,and without it its louder than I would like.
Try cutting off all but the end piece with the screw socket welded on. Works great, not too loud, breaths easier, still bolts right in. and much quieter than wide open. The pipe part of it with the four holes and flange aren't needed.
Make sure you've done the powerup jetting.
Thanks I've done the power up .
I've already cut off the Bulb where the packing was ,and cut it shorter too ,but left the area with all the holes in it and as I said it makes a silly whislte on .deceleration .
I'll try cutting those holes out. Thanks.
