Need To Shim Carb Needle!!
I need to richen my mixture. So the needle needs to go down further, right? If right so far, then I need to put the washer just under the slider cap right? Sorry for the confusion. Lastly, to adjust the auto clutch, all the way in and out 1/4 turn? I am having the kick start slipping problem and want to be sure this is adjusted correctly. Thanks much in advance!!
Dude, you put the shim under the circlip(jesus clip) that's on the needle.
That in esscence raises the needle richening the mixture.
On the clutch I turn it in till I feel resistance, back out 1/4 turn and then tighten the lock nut.
You really should invest in a manual if you're gonna diddle these little bikes.
It really helps.
