04 WR250F 78 bars to 1-1/8 bars
Who makes the best 7/8, that will not bend after one drop?
After changing 7/8 to 1-1/8 with adapters it changes the handle. Has anyone tried newer model wr upper clamp on older model or has anyone had the stocker machined out to 1 1/8?
OOnor: I recently got a pair of Pro Taper adapters for my older 2002 WR250 & like the quality alot. I installed some Flexx bars & the only problem I had was with the height; since the adapters raise the bars slightly, my cables wouldn't "stretch" to the levers; I had to trim about 3/8" off the bar ends. So, just be aware the adapters raise the bar height & you may run into the cable issue. Hope this helps. Bob in AZ
I purchased the Applied top triple clamp and it works fine. I did this instead of adapters because I run a damper. :p
Nocturnal, what is the part number? Did the upper clamp let you put the stock light and mile counter on?
I have the stock light but I never tried to mount the odometer. I installed a Vapor at the same time that I did the triple clamp. I am pretty sure it was THIS ONE.
