Wheeeeels
Is there a step by step guide to taking off wheels and putting them back on?
I have a 2003 CRF450R, and I just bought some supermoto wheels.
Just be sure you take the old ones off first. :p
dude
loosen the bolt oon the side wile holding the other side.
then pull the axel out
put your new rim on ur forks
put that axel back in but grease it up cause if you dont know how to take them off there probably dry like no other.
do the same to the rear just put the rotars on the right side
also when u put the chain on...and adjust for slack....make sure the adjuster exactly the same for both sides, as i assume that the s-moto sprocket will be smaller
