drz400 plastic??
What brand of plastic does match the most to the original yellow suzuki
Because i order ufo and they are not the same at all it will not match my
graphic kit .
Thanks
About your best bet is buying the OEM plastic from TT OEM store. ALL aftermarket mfr's have to try to match the oem spec with colorant they buy from their supplier. I have seen posts where somewhere around 2002 Suzuki changed their yellow slightly so its a crap shoot.
Best bet s to pull your fender and take it with you and see what matches. The OEM may not match perfectly as your bike has been exposed to light, UV, water, mud weather etc.
You can also get new graphics pretty cheap from several vendors, Wheeling Cycle Supply is one of them.
I bought an Acerbis rear fender for my '04 yellow E and it matches great.
I got the ufo front fender and it matches everything but the headlight shroud, that only because it is the most weathered. And I'm having a hard time finding a replacement.
Look like they don't make radiator shroud from acerbis for the drz400
What will fit and does my graphic kit will be ok Because i have a graphic
for the drz400e
They absolutely do make shrouds. I got a set of Acerbis shrouds in black on my DRZ-E
