Question about running a stock sm front rotor on an S
The link didn't work, but most brackets make room for the 320mm rotors. The 310mm rotors will be too small.
Fixed the link.
Thanks for the info, makes sense. I was thinking that the oem front sm rotor was 320mm for some reason. Sounds like all I need then is that relocator bracket as shown in the link and an after market 320mm front rotor and I'm good to go, unless I buy a kit. Main thing was I just wanted to confirm that the bigger 320mm rotor and relocator bracket will work on the stock S front wheel as I'm not running sm wheels.
It works great!
that's an ebc 320 mm rotor with it's own bracket.
isn't the op asking about the oem 310 mm sm rotor?
ahha...helps if i read subsequent posts......so ya, that will work .....
