xr650r Newbee!!!!!
Hi, Can someone tell me ,how many turns out for the pilot screw (gas)...
and how many turns out for the air screw, both have been seated.....
it use to start, two kicks on full choke, but i've messed with the settings
and now it won't start . 2002 xr650r ,it has not been uncorked.....Thank
steve,,,,,AZ
Start with at least two turns out on the fuel screw but what air screw are you talking about? Idle(under the carb facing up)? If you messed with the idle speed, just crank it in(clockwise) a ways and you will know if it is too high once it starts. Hope that helps. :p
