04 RM 85 no power with throttle open
Just got 04 RM 85 bike starts 1 kick runs great on a stand power valves open. Bike had top end rebuilt 1 1/2 years ago sat for 1 year. I cleaned carb drained gas flushed put new in. The problem is when you ride up to 1/4 twist runs great past that it feels like it is hitting rev limiter not bogging just hit and miss all the way to WOT.
I have checked floats, reeds cleaned carb,and air filter. Changed jetting it makes vary little difference. I have never had a problem like this before I have adjusted carbs don't think that is my problem.
All mods I see are vforce reeds, PR2 cool head, stock pipe, carb jetting primary 50 main 128 needle 24NAAH.
Thanks for any help
Sorry forgot to put that in changed and checked plug showes the carb is good.
Sounds like you are missing a powerband :p
It seems like a throttle valve problem. Take the throttle needle out of the carb and try raise or lower the clip and see what happens. This is responsible for the 1/4 - 3/4 range.
I had a similar problem with my RMX, fine 1/4, ran like crap to 3/4 and then went like a madman to 4/4. Ended up being to lean.
Found problem bolt missing off bottom of coil to ground wire to coil. Put bolt in runs great from idle to WOT.
Thanks for the help
