Supermoto front caliper...
So, This morning on my fun day of mechanics, I Messed up my front caliper..
No, I don't want to talk about it.
What are some cheaper aftermarket brake setups that some of you guys run?
Figure If I'm going to spend money might aswell upgrade right?
Aloha.
-patch
Aloha.
-patch
Aftermarket calipers aren't usually cheaper...your best bet may be to buy a used OEM caliper off Ebay or from someone here who upgraded to Brembo's. I like the idea of trick aftermarket brake calipers but the cost is always more than my budget will allow. You should be able to get a good used caliper for
under $45 which is better than the $275 the dealer wants. Are you comparing the aftermarket caliper prices to the full dealer price? You may be better off to consider a used oem caliper and a set of steel braided lines...just my opinion of what I would do unless I was a hard core track guy.
Well, did some more research and I guess I was asking for the cheaper of the aftermarket brands, the beringer is the cheapest, And one I'll probably choose..
But quick question I did fix my stock caliper and put the new pads, but now I got this metal thing and dunno where it goes..can some one point me in the right direction?
heres one pic
