00 KX250 shift troubles
Finally had a warm day and some time to mess around with my bike so I buzzed around the yard with it. Trouble is it wouldn't shift past third??? I have changed the oil over the winter but haven't tried to go past third until yesterday.
Clutch feels fine, shifts down 1 and up 2 just fine, but won't change after that?
I'm looking for any and all thoughts, ways to clean things up, thoughts on re-building...anything, I'm stumped.
Check the shifter with the clutch cover off and watch everything move, if everything looks good you may end up splitting the cases and checking the shift forks and the shift drum. Is there any chance you put a different drain bolt in that may be longer and hitting the shift or something. Good luck.
Ed
