cr500 brake
when i ride my cr500 it dosnt seem like its goin fast like it used to could it be from the rear brakes or the clutch any informatio nwould be greatly appreciated
You can check the rear wheel spin by putting the bike on a stand and spin the wheel. If it spins normal then the clutch is slipping. How often do you change the trans fluid? Drain the motor oil out and put in some ATF type F. The bike will be so fast it will leave a brown stain in your tighty whities!:p
