Bought a used bike with pro circuit suspension
I bought a 98 kx 250 with pro circuit suspension .41 fork springs,5.2 rear shock spring...im pushin 200lbs I havent rode the bike(down for rebuild) I noticed one of the fork seals leaking also.My ? is would this spring rate be ok for woods riding/occasional track? And do i have to send the suspension out to PC to have the fork oil changed seals put in,mainly a going over.Thanks!
the shock is correct for you, i have a friend with the same age bike, the forks sound a little soft but i have found with the pc kit forks(49mm ones) you can run softer springs than on a 47mm fork.
