Got new foot pegs, now they mount slightly downward, what to do?
I was warned about this, but wasnt sure on how to order the right foot pegs. I got some wide with stud style pegs, I like them except for the tilt they have when mounted.
any fix?
If I understand you correctly they hang downward at rest? sorta like this:
if your viewing from the front?
If so, I had the same problem on a pair of aluminum pegs I bought that started to sag. I drilled and tapped two holes in the bottom part of the peg shown below and put a small phillips stainless screw in there to take up the slack. It did the trick and lasted as long as I owned the pegs. I would take a pic but they were sold awhile ago, hence the photoshop illustration.
wow thanks for the effort! but they dont tilt like that, its more so they are tilted forward, feel good when hill climbing, but weird everywhere else.
try fliping them around maybe on backwards,, when you buy pegs you should also get the peg mount also,, cuz the stock one will bend just matter of time.. the best set up i think is the two bros mount with fastway pegs.. they are adjustable..
