Progressive spring for shock?
I hear a lot about using progressive springs on KTMs. Will one make an SX more offroad friendly, or do you need to revalve as well?
is it sprung for your weight now?
a different spring may make it better, progressive or straight makes no difference, the system is designed for a straight rate tho.
I'll be picking the bike up this weekend (09 SX 250). The spring rate should be good (I weight about 180-no gear).
Congrats!:)
you could use a different spring. let us know how the sag #'s work out, with gear. I think the spring will be too light.
as far as SR vs PR, I liked a progressive spring on my stock 06 300 and 07 SX shocks, and I luv my revalved 05 shock with a SR spring on it. done right, either will work. the progressive will give the stock shock a little better feel.
My '08 300 XC-W came with a progressive spring...it was too light (a common issue if you weigh more than 190lbs w/ all gear). I replaced it with a slightly beefier progressive rate spring.
Since KTM's lack the linkage found on the Japanese bikes, the progressive rate spring works well to smooth the initial shock travel. The linkage on the other bikes actually give them characteristics similar to a progressive rate spring.
Non-linkage bikes are more sensitive to spring styles and rates...so getting the sag settings correct is essential. Be sure to measure and set sag in full ride gear (including filling your hydration pack - if you use one - and the bike's gas tank).
I purchased my new spring from Factory Connection. They have extensive experience with KTM. Call them about a possible spring...they'll ask you a ton of questions and make a recommendation based on your answers.
Good hunting.
-Jay
A revalve is best if you're looking for plushness. That said, I prefer straight rate springs.
Good hunting.
-Jay
Jay,
Your bike came with a 6.9 straight rate spring.
different companies have different setups. some like straight for easier revalving. factory connection used progressive for my xc-w when they revalved (i weight 230 with gear). race tech has a webpage that talks about their recmondation to use progressives
your stock shock is valved for a straight rate spring. if you put a progressive rate on you should have it revalved to get the most out of the progressive spring. straight rate vs. progressive rate spring = preference. if you ask 10 suspension tuners for a ktm which is better you will get 10 different opinions on which is better and why!
Jay,
Ooops...
I stand corrected. WP 69-250 Straight Rate Spring.
Thanks Cactus.
-Jay
Race tech is NOT a KTM specialist, most of those that are use straight rates.
Iver used both and cant tell the difference. I use straight now cuz they are way cheaper to buy.
Well..... I guess I disagree w/ some of you
I was racing my 08' 250sx off-road ( expert ) 170lbs.
& it was wearing me out , tried diff. straight & prog.
ended w/ Ktm's pds6 progressive on the back ..
much better absorption of the trail junk than the others
Ultimately I went the re-valve route , it's great ( still pds6)
that's my results , suspension is very personal.
I went with a progressive spring and a revalve from Slavens here localy, I love it
Thanks for all the info. I bought the bike from ktmworld, and they offered to revalve and respring both ends for $500, so I went for it. I'll post a ride report if it ever stops raining here in GA.
I have a Factory Connection rear progressive spring for a 170 # rider I'd sell for $100.
Cost $150 new and only used a few times as I weigh 180# it was not quite right.
Very easy to install yourself w/ normal tools btw.
PM me if interested.
how about PR springs for front?
Byte
So, with stock valving, its best to stick with straight rate springs correct? I have a progresive from another bike but dont want to use it if I shouldn't. I dont have the funds to re-valve at this time.
I used a progressive spring on my 06W, 07F, and 07SX with no problems. it may not have been perfect, but it worked. you will be fine.
how about PR springs for front? No.
Byte
I use a straight rate on my 08 per Javier [Trail tricks] advise and it works very well with his set up. My 07 has a progressive on it and it works well also, so like was stated it is really a personal thing. Or if you suspension valving was set up for either spring than stick with that.
