05 450 R High Tention Lead
Hi I have been stripping my 450 R to check valve and decompressor clearances as having troubble starting with the kickstart. When i removed the sparkplug cover i checked the high tention lead and it slid straight out of the sparkplug cover. I was wondering if this was normal as you cant remove the other side from the coilpack.
This dosent seem normal to me, even if this was the case i would expect to see a little bit of the inner ht lead coming out.
Thanks for the help at a loose end :p
