RAM mount How-To
I always liked the RAM mount system, but I didn't like the available hardware.
When I changed my mirror location, the stock mirror mount seemed like a perfect place for one. I bought my stuff from these guys:
http://www.WhitehorseGear.com
You'll need:
2pcs Extra Ball w/ internal threads #N-B3093U (or just one for 1 side)
1pc M10-1.25 bolt at least 45mm long or 2pcs 30mm long
2pcs M10-1.25 nuts
2pcs 1/4-20 all-thread 1" long or you can cut down bolts like I did
Tools needed:
Drill and drill bits
Tap for 1/4-20
Cutting oil
two 17mm wrenches
metal vise
Blue Thread lock
Saw 15mm sections with a hacksaw and using the side of the nut as a guide, you get nice square cuts. The nuts will also help you get nice threads back after you cut.
These are the M10 bolt sections ready to be drilled and tapped:
Now find a 1/4-20 bolt and cut-off a 1" section, apply blue threadlock to one end of 1/4-20 bolt and screw into female RAM mount apply BLUE threadlock to other end and screw into the tapped M10 bolt section.
You're done. Should end up with something like this:
PM me if you need more help.
Cheers,
Tony
Dude that is a nice piece of work, DO you have pics of it on the bike with your GPS/phone/cupholder attached?
I had been thinking the same thing when looking at the Rams for my Garmin 205.
How much to make me one?
I just came across this one that should screw into the mirror mount:
http://products.ram-mount.com/rammount/productdetail.aspx?partnumber=RAM-B-349U
Nice find, I guess I shoulda did a search on the net:bonk:
Stoopid me trusting the hardcopy mail-order catalog to include all available hardware.
Oh well, I think my mount is stronger than the one you listed:banana:
