gasket, o-ring question
I am doing my first top end and I am going to start putting things back together. So far it has gone pretty smooth. My question is do I need to do anything to the gaskets and o-rings to get them to seal good? The last thing I want is to get everything back together and have something not seal up. I know the manual recommends lithium grease to the o-rings. Anything else I should do?
Just make sure everything is clean then torqued down to specs and you should be good.
that's it, make sure base gasket surfaces are clean too.
