dynojet jet kit question
working on an atv for my brother, stock jetting is:
45 pilot
152 main
fixed needle
not sure on the fuel screw.
Put an FMF powerline slip-on on it and bought a dynojet kit so I could get the adjustable needle. My question is the kit recommends:
45 pilot
146 main
3rd clip on the needle
3 1/2 turns out on the fuel screw.
my biggest issue is the fuel screw, everything I have read said any more then 3 turns out on the screw means a bigger pilot. So what recommendations for a starting point on the pilot, also main seems small as well.:p
machine is a 2003 honda rubicon. we ride between 4500 ft and 10500 ft, winter and summer. (0 deg - 100 deg)
the dynojet needle has a different taper so it uses different main jet.
ideally a abigger pilot jet would be good but i would just install the kit per the instructions.it will run fine.
