125 sx light
i was wondering if i could put a light on my 125 sx?? if so is there a way to make it where the battery charges off the engine??
I don't think there is but I would check with Trail Tech to see if they have a kit since they make all kinds of lighting stuff.
Absolutely do-able. You'll need to get a k3 stator and flywheel. The k3 will get you roughly 100watts peak power. The K3 stators would commonly found on the offroad models, exc, mxc, xcw. Any twostroke k3 will fit, even if's off a 250 or 300. A K2 would power a headlight also, but it's only 40watts, they came on some of the newer 200's and 250/300 xc's. Do some searching on ktm talk . com to find them used, they come up on ebay often also. It's pretty quick and painless swap.
so would that just be for a light??? is there a way to get it to hook up to a battery cause i would like to get a helmet light too!!
