forks & shock from a yzf450 fit a yzf250?
Will a suspension from a 2007 yzf450 fit a yzf250 same year?
The shock appears to use all the same parts, I understand the stack will differ between the too models. My guess is the shock is the same other then valving.
Most of the forks inter part appear to be the same, but the tubes both inter & outer have different part number. If both bikes use the same triple clamp, what is difference with the outer tubes?
I guess my question is will the 450 parts fit the 250? And if not what is the difference?
Thanks, Dan
i am pretty sure they will fit, the valving often on yams hardly vaires from 250f to 450 , its mainly the springs.
