Carb Issues Indian moped
Alright, I finally got this thing running after finally finding a push rod online...
BUT!!!
I cant get the carb tuned in
Heres the set up:
21mm keihn
K&N
58 Main
38 idle
Starts up perfect, has the classic case of "only runs on choke". No air leaks, everything is clean, fresh o rings/gaskets it also seems like its pulling in alot of fuel. I can fill the fuel line up all the way and it will run for 2 min. before running out. Seems like alot of fuel for a 50cc engine.
Am i missing somthing?
Will not idel without choke.
I think I know what it is, I just thought about my carb size vs my engine size. May the carb be way too big for the 50cc engine? So if I put 50 main jet do you think that should cure it?
