Changing bars on my 08 WRR?
Well I've finally decided that I'm going to change the bars on my 08 wrr and I have a question about the grips??
Do I need to replace them or can I use the ones that came on the bike?
The bike only has a couple hundred miles on it and the grips are in new condition I was hoping not to replace them !!
Any help would be greatly appreciated!
Thanks
Oh yeah I'm switching to Protaper contours! 1 1/8":ride:
I reused my stock grips but getting the
Clutch side off took some serious elbow grease.
I also reused the stock grips when I switched to a set of Pro Taper EVO bars.
I soaked the grip end of the bars in hot water for a few minutes then peeled the grips off inside-out, it was a bit of a pain but I'd do it again.
Ditch the grips! Replacing the bar and leaving the grips is like buying a Mercedes and moving over your old purple seat covers with flames.
The stock grips are easy to get off. A little trick I learned is take your air gun and slip under the grip shoot a little air and it just slides off. Same with putting them on if you don't use glue. If you have an air gun that is. I hope this helps. I wish I was smart enough to figure this out myself.
Ya the compressed air trick works real good, i thought that was my idea! But ya, a blow gun with a small little air outlet makes it easy as pie
I got the pad at the local shop but Rockymountainatv.com or motosport.com has them.
Thanks for the info guys!
I went with protaper contour's w/woods bend and the protaper rubber mount's.
The reason I went with this set-up is mostly because of things I read on this forum!!
Thanks again for the input guys!!
Cheers!
Those evos look good but i dont see any mirrors. Whats a popular bar for mounting mirrors to also, can it be done with Evo bars ok?
Post pics of your bars so i can scope e'm out!
The mirrors just screw on to the factory brake and clutch brackets. I just did not put them back on for the picture.
