Gearing, What would you do?
I'm planning on only driving my DRZ on 60 and under roads...
What sproket changes would you make? If you would never take it on a highway what would you do?
Chet
EDIT: Where is a good source for gears?
14/47 seems to be a nice blend for a lot of bikes. i'm using it now. i like it ok
Chet
95% off-road my preference most of the time is 13/48 or 13/49.
If I have a day or trip that is mostly fire roads then 15/48 (easy to just swap the front sprocket).
Im running 15/48 on both my 05 s's . You can do 55 to 60 real nice for nice long runs . You can do 75 in spurts. Good all around off road gearing also.
I'm running 15/47 gearing, it works out perfect for me. I can get up anything offroad (in the desert) and it goes 60mph okay. Over 65 is pushing it, but I never take it on interstates so it doesn't matter. I think steel jd sprockets are okay ones to get, that's what I plan on getting. TT store has all sorts of sprockets.
Where should I look for gears?
TT Store...give them a call.
I do 14/47 which is pretty close to being about right for me in the deep woods, is a wheelie monster around town, and can buzz at 70mph (more comfortable at 60 tho) when needed to.
^^^ Would I need to adjust my chain if I'm running the stock SM gearing?
Basically I'm looking for some pep around town... Take off speeds and 25-45 grunt...
Chet
What does changing the gearing get you... Say the 14/47?
14-47 is nice for the woods,to tight for extended street riding.
With my street wheels/trail wings i like 15-46
Off road wheel set 14-47
i am runnin 14/50 talk about some pick up and go.. jet kit 3x3 full exhaust and cams... havint met a 450 motocross bike than can beat it out of the hole yet..... 14/50 is when u wana wheelie in any gear without standin up
Stick with stock sprockets, best compromise between some dirt and mostly road. Swapped the stock 15T for a Driven 16T primary sprocket for in town commuting, works nice at fwy speeds. I don't shift to 5th til 50-55 mph. A jetted BSR-36 will pull that ratio, CVK-40 is better, FCR is better yet but taps out my go faster budget.
