Project R Complete!
After five long months of modifications, Project R is finally done! For those of you who wonder if it can be done, I present my bike to you. You can see the starter in the pics of the motor, and it really is fully functional.
It's actually an X with a full R rear end/exhaust. I mounted the battery over the airbox using a battery tray that I fabbed out of AL. I used disconnects on the wire harness to allow for easy removal of the entire setup. You would never know it, but I actually found it easier to change the filter on my bike v. the stock bike sans having to remove the seat. I modded the wire harness to remove the headlight and taillight circuits and shortened the negative cable to reduce weight. This eliminated two pounds from the harness! I had to move the CDI, so I fabbed an AL bracket and mounted the CDI to the back of the radiator where the aux fan would go. I will post pics of this if I get more time and good weather as it is freakin cold here right now.
List of mods I did this winter below:
ENGINE
07R head (polished exhaust ports)
RHC Intakes and springs/retainers
New exhaust valves/springs/retainers/keepers
08R cam
08R piston
Decompressor Mod
New timing chain
Changed jetting to specs from AS as a baseline (will adjust as needed)
New No Toil Filter and Cage with PC pro seal and Filterskins
Moose Racing/ZipTy Magnetic oil filter cover
New Hour meter
Suspension
New Fork springs & fluid
New Shock Spring and Fluid
Drive
New Ironman Rear Sprocket (51t)
New Front Sprocket (13t)
New DID ERV3 Chain
Tires
New Bridgestone 603/604 tires (changed them myself!!!!)
Other
New Radiator shrouds (Cycra Powerflow)
New Rear Plastics (for R rear)
New Mud flap
New Graphics (one Industries Torco)
New seat cover
Removed ODO and cable
New fork Protectors (R version)
R seat
R gas tank (Made an AL bracket to mount to the frame)
Ebatt (system charging)
I already had:
Cycra ProBend Handgaurds
Cycra front stadium plate
Maintenance:
Regreased everything
Changed all oils
Good job, looks very nice and probably runs much better than it did:thumbsup:
Nice job. Any reason you didn't just buy the R?:)
I have posted that in retrospect I would have rather bought the R. But, since this was my first dirtbike I did not quite know what I wanted yet and the Estart sold me on the X. After seeing all the posts on whether or not you could put the duals on an X, and all the replys about how much work it would be, the tinkerer in me got the best of me and I had to try it! I got some parts off of TT members and many parts off of eBay. Minus the costs of the engine modifications/repairs it really wasn't all too bad. Now I have a bike that is in an elite crowd (as I am sure someone else has done this whether or not I have seen it), and I have a bike that has both parts that originally drew me to each (starter and duals). I have not weighed my bike yet but I know that it is pretty light.....not quite an R light, but way lighter than an X.
All in all I love having the estart, but I have always loved the look of the dual exhuast.
sick bike man! what is your est costs with switching the subframe and exhaust? do you have a lithium batt. if not that would be the icing on the cake for losing weight and becoming more Rish. I would love to do this conv to mine.
yes I have the lithium battery from Ebatt. It is the self-charging model.
I paid the following:
subframe - 150
airbox/full exhaust - 185
plastics - 80
MISC hardware - 20
Nice makeover man. I love seeing people's hard work and inginuity at work and coming together in a kick ass project. Do you ride trails or MX? That would be a pretty sweet trail ride with the X gearing and the R mods you've done to lighten it and gain some power.
How's it run?
Good job man, and now if you stall it in a corner or drop it you can hit the magic button and be on your way without:
A: Wearing yourself down from kickin it..
B: Losing a bunch of time..
How's it run?
I ride both. Probably a mix of 60 trails/40 MX.
Actually, due to the cold I have not ridden it yet. I checked starter/electrical operation and broke it in with the dry method, but I have not ran it yet. As soon as it warms up a little I will get it out and report back. I have spoken with many people about the combinations of parts that I chose and am sure that I will like it. I posted this first because I was so excited to finally have it all together! Should be warmer here soon.
Looks great. Good job.
Those graphics can be a pain to install.
if you're refering to the one bubble on the radiator shroud, i'm not sure what happened! it was bubble free when I put the graphic on there, then I put the shrouds on the bike, and soon after....bubble. It is the same on the other side as well. I did not even notice it until I saw it in that pic! Luckily it is very hard to notice from 3+ feet away. I already tried pushing it back down and I can hear the adhesive stick then release. Those shrouds were brand new and cleaned with contact cleaner before the graphics went on.
Did you try poking it with a needle to release the air? Poke it with a needle, then work the air back out through the tiny hole. If you don't release the air, the pressure won't allow the sticker to say on the plastic. ...but you probably already tried that.
Great job man. I feel the same way about the mods as you do. I've always wanted a combination of the X and R. I would like to have the E start with the close ratio transmission gearing of the R bike.
Heat it up with a hair dryer and try to get it to stick.
Tried that yesterday and got it to work! Thanks for the suggestions..!
You bastard:foul:
you stole my dual exhaust dream!
oh well, at least I know what is involved now:thumbsup:
awesome X
sorry man....but I can help you with the conversion if/when you want to do it
