bike not starting
well it ran fine up untill i washed it then i started it and it ran but boged realy bad i put a new plug in it and still bogged realy bad and it backed fired every onec in a while it would back fire so i took the carb off cleaned it out it put it all back to gether and it dosent run but it still back fires any ideas
Sounds like you have water in an electrical connector somewhere, go round the bike and pull apart all the connections and clean them out with electrical cleaner and an airline to blow any water and cleaner out :)
push it to a tall hill and throw it off and buy a new one. LOL j/k
there are many things it could be. i would remove the air filter. and try to start it. if that dosnt work. do the wiering connector overall check. i would drain the fuel and put some straight fuel in there and see if it will start. if it fires up turn it right off then drain that and put some mix in.
