KLX cams
Do you guys know what you would have to do to get KLX cams to work in the KX. Cam timing, valve adjustment etc... Thanks
To get 'em to work? Just bolt them in. If you use their cam gears, you just bolt them on through the single holes, and you got yourself KLX cam timing.
Edit: I should make this more clear.. The exhaust cam is the one you'll bolt on because of the auto-decomp release. The intake has the cam gear pressed on already.
Could somebody measure the cam lift on the stock klx/kxf cams?
You can't just bolt them in you will need a complete KLX head.
I know that,just want to know the difference between them.
I wasn't talking to you, I was talking to the two people above you that said you can just bolt them in.
If you knew that already you should have at least let them know. :)
I didnt say you could "just bolt them in'' now did I hmm? :banghead:
Ha ha, no you didn't but you did say "they both should be swapable" which is not true. :banghead:
The guy above you did say they would bolt in though. :)
Ha ha, no you didn't but you did say "they both should be swapable" which is not true. :p
I GOT THREE THINGS TO SAY TO YOU PAL.
:foul::banghead: :banghead:
